Re: Why BBB Method?
IF you don't have a cartridge filter or a non backwashing DE filter.
IF you have a short swim season and winterize your pool (which means a partial drain, usually)
THEN using pucks in a feeder usually does not present problems with CYA getting too high too quickly.
IF you have a cartridge or non backwashing DE filter, an extended swim season, and live in a climate where you don't have to winterize your pool (or any combination of the above) then, IMHO, using pucks will lead to elevated CYA levels before the swim seaon is over and you might find that you have outbreaks of algae a few months into it (Could there be cause and effect why most Mustard Algae outbreaks are seen around August?)
Just my 2 cents!
