Re: Trouble getting CC to zero.
It's definitely overkill if your pool is at shock level! When it's not it doesn't take that much longer or that much more reagent. I was told .4 cc is acceptable, .5 or higher - shock, thus I measured with the 25ml level. LOL - I guessed .6 on my cc now, it was just barely pink after adding one drop of 0871. It actually could have been .7 or up. Sometimes you just gotta guess
Richard, I was told to only use one dipper of the DPD powder regardless if you were testing using the 25ml line or the 10ml line. Quite possibly I was told wrong, but it was from a very reliable source. You're absolutely right on the aeriation, but for now we're starting our planting season and didn't have the time to hook up the fountain, and too cold for these bones to jump in! The borax was handy and quick. My TA is a little high, but I read it's ok as long as it stays under 180. It'll drop as we start to swim too --- that's those times when I need a little muratic acid as my daughter is 10 and we have her friends over a lot - so it gets a lot of aeriation!
Will check the chlorine and cc levels once more before going to bed - will let it come down and get my solar blanket on tomorrow. When you fill with iron filled well water you don't want evaporation either.
Matt 4x4 talked about a brown dust algae where he had to overshock to get rid of it... wonder if that's what mine is. I don't think I want to shock over, let alone up to 19 again, as I don't want my iron to fall out.
After my chlorine drops to my normal rate I'll recheck my cc using the 25ml line and repost the actual number. I think I'm just gonna have to live with some cc in our pool. Thanks again!
Sincerely,
Donya (huskerfan)
