Results 1 to 4 of 4
Thread: CYA and aquarite
    Default CYA and aquarite
    What is everyone using as an CYA level with Aquarite. I think I was around 40 last year, but thought I would try 30 this year which is what it is at right now. The manual says 80, but that seems high to me.
    thanks!
    tonyl is offline Registered+ Thread Analyst tonyl 0
    Indiana
    Default Re: CYA and aquarite
    Generally 70-80 during the summer months. I'm currently at 40. Increasing the CYA just helps the chlorine residual stick around longer and reduces the load on the cell.
    waterbear's Avatar
    St. Augustine, Fl
    keep mine between 60-80 and it's been fine with fc at about 3
    Katy, TX
    I run mine at 40 ppm, 40% and run the pump 6 hrs/day. Seems to keep up fine. I prefer a lower CYA because high CYA causes:
    • Reduced effectiveness of Cl
    • Accelerates plaster erosion
    Cells are cheaper than a plaster job! I've had mine running since last year, and have yet to trip the hour limit that tells you to clean the cell.
    Michael
  1. aquarite swg
    By pc boy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-10-2006, 03:46 PM
  2. What's better than Aquarite?
    By jacksonlui in forum Pool Equipment & Operations
    Last Post: 06-14-2006, 11:35 PM
  3. CYA and Aquarite
    By bethsg in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-08-2006, 09:54 PM
