Re: Help: any opinions on best SWCG: Poolpilot, PentairWatermaid, Aquarite?
I run from about 8am to around 5pm (solar heating), then again for about 4 hours at night. I just installed a multi-speed pump (Ikeric), so I will likely be extending my night run but at a much lower speed/gpm.
Due to the way the SWG works, I think (my own opinion) that it is better to run longer but lower so that the pool is more constantly chlorinated. SWGs work low and slow (low level of chlorine added, so more time is needed). You can vary the % of output, but what you are really doing is varying the amount of time during the ON cycle that CL is being generated, not the amount of CL generated (at least with the Aquarite). So, by running longer but at a lower %, the CL generation gets spread out, so (maybe) there is less of a roller coaster effect on FC in the pool. That is one of the reasons for using a 2 speed pump, it reduces the cost of running the pump so I can run it longer. (Hope this makes sense).
