Thread: is there a borax calculator?
Threaded View
  1. #2
    Default Re: is there a borax calculator?
    Quote Originally Posted by pairadocs View Post
    Also, do I need to dilute the borax in a bucket of pool water, or can i just throw it as dry powder into the pool?
    thanks,
    bob
    How much Borax you have to use will depend...the higher your TA is, the more Borax it will take to raise your pH. For example, in a pool with a TA of 100, it may only take 1/2 box to raise pH by 0.4-0.6, but in the same pool with a TA of 180, it will take much more Borax to raise the pH by the same amount. It also depends on the volume of your pool.
    I pour Borax as dry powder into the skimmer and let it dissolve from there--I see results in my IG pool within the hour doing it that way.
  1. The Pool Calculator
    By Scetnk in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-25-2011, 02:17 PM
  2. chlorine calculator
    By azimmer1 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-26-2006, 11:58 AM
  3. bleach calculator
    By michelob3232 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-01-2006, 06:54 PM
  4. SI calculator
    By p.p.h. in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-26-2006, 01:08 PM
