Thread: thepoolcleaner... will it work for my pool?
    mas985's Avatar
    Pleasanton, CA
    Default Re: thepoolcleaner... will it work for my pool?
    If you can isolate the return to just the cleaner or partially to the cleaner, you should have no problem at all. Your best bet is to put in the valve so you have some control of pressure and flow.
    Mark
    Upstate, NY (Dutchess County)
    Default Think I'll go for it... Any issues with leaving it in the pool all the time?
    Are there any issues with leaving the cleaner in the pool and running all the time (except for when swimming. Our season is usually from June through August. That would mean with 110~120 days and filter operating 12 hrs/day about 1000hrs/season.
    26,000 Vynil Liner L Inground
    Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
    Poolvergnuegen thepoolcleaner Pressure Side Cleaner
    Loop-Loc Mesh cover
    Sugar Land, Texas
    With only two returns, it should work (no promises!).
    I have six returns, so there are too many alternate paths for the water. I am having to put in a booster pump.
    Pool owner - contract signed 21Aug2006; HOA approval granted; complete - existing patio demolition; excavation; rebar; embedded plumbing; gunite; plumbing; electrical; tile and coping; decking; plaster; pool fill; acid start-up; regular start-up; pool school; gas meter upgrade; additional of salt; PDA remote programming.
