Results 1 to 10 of 11
Thread: The new steps are here!
    Default Re: The new steps are here!
    Not sure what you mean by anchors - no anchors with this set. There is also no bottom platform. Its all constructed out of the pool and placed in, with the weights in it before putting in, but I guess you could put them in from the pool as well. I got a chance to read the instructions last night and it looks pretty straight forward. Everything went together in about 5 mins except the final hand rail/deck attachment part due to some possible mods we may make before installation.
    Do you have Biltmore steps? They are the flow through type of steps so there is no place for air to be trapped and the weights (they say 50# sand, but we will use concrete filled bleach jugs) go into a compartment that opens up in the second step down. I know we need to get the mat set correctly before we put them in, but thats no different than with our ladders in the past. I'm gonna get the shower stall vinyl CarlD was talking about just to be on the safe side, we DO have sand underneath, not the gorrilla pad/cove stuff so better safe than sorry - protection. We always used a thick mat for the ladders, will use one now. Off to Lowes this morning for supplies!
    TN.
    We have these steps. We usually just set the steps on the edge of the deck and put the sand bag on the shelf. Then we each hold onto one of the sides and slowly lower them into the water. Same thing to pull them out, we never get in to do either. Just make sure that as you put them in the little "feet" on either side don't fall off, and that you have them out far enough they don't scrape the wall. We love these steps, they came with our pool. We've never had a problem with algae growing around them like our friends who have the wedding cake steps. I'd take a pic, but they're covered by the solar cover.
    Karen
    18' AG
    Smile Re: The new steps are here!
    Ditto to what Karen said - I've never gotten in a pool to place the steps or remove them, the only part of me that gets wet is my arm (up to the armpit w/sandbags, hence my suggestion to tie ropes to the jugs) and possibly 1/2 my face when I have to 'dig deep' for a &$%^*^& sandbag that's just out of reach
    Oh thanks you guys! I picked up the plumbers vinyl mat yesterday to put under the steps (our old mat was just a bit too small to fit them) so I will cut that today and get DH to help put them in. We are going to use the bleach jugs with ropes for sure - what a great idea that is.
    mohawk is offline Registered+ Thread Analyst mohawk 0
    Minneapolis, MN
    We have the wedding cake II stairs. I haven't had any problem with algae but with the weight. These stairs have 3 sand filled anchors that are screwed to the underside-plus a removable top step. Do you suppose some of your suggestions would work for these stairs? My husband HATES to put them in and out. He thinks that's why he hit the wall last year and put in 2 holes. Denise
    The jugs filled with sand or concrete with nylon rope attached is the best idea I have heard. We haven't gotten the steps in yet due to yucky weather, but the jugs are ready to go. The ropes will be run up the back and tied off so that they are easy to remove when its time to pull the steps out, then the steps will be easier and lighter to pull up. I would think it shouldn't be much harder to do with your steps.
    rilesworld is offline ** No working email address ** rilesworld 0
    Nashville, TN
    What is the plumbers vinyl mat that you picked up? I am looking for something to protect my liner from a home made swim platform that I am working on. That sounds like what I am looking for. Where did you get yours at?
    Thanks.
