Re: Slightly Cloudy Water after Opening
Yep, just be patient. Slightly cloudy water is totally normal, at least for a day or two. If you normally run your pump on a timer, be sure to let it run 24 hours a day for the first several days when you open the pool. After the water is crystal clear, then you can go back to filtering 8 or 10 hours/day or whatever works best for you.
