Results 1 to 9 of 9
Thread: White foam on cloudy water
    crsuarez is offline ** No working email address ** crsuarez 0
    Default White foam on cloudy water
    I have been shocking my IG concrete pool with around 15 ppm CL since opening, a week and a half ago. It was green like a pond. Now I have a nice blueish couldy water but it is showing some white foam on top.
    CYA: 40
    FC: 13
    CC: 1
    pH: 7.5
    TA: 140
    CH: 150
    The Ph was above 8.2 to start. Using Muriatic acid I was able to bring it down to 7.5.
    I'm only using bleach, Clorox (6%) and PurePower (regular scent), a brand sold in Giant Food Stores (Washington DC area) which I believe it is also at 6%.
    What is causing the foam and how can I get rid of it?
    Thanks for any help you can provide.
    Dec 2005
    South Carolina
    Default Re: White foam on cloudy water
    The cloudyness and CC of 1 say you're definately still fighting a load of some kind, so keep up the shock level bleach usage.
    I'm wary of the "regular scent" bleach. You should only use regular bleach. No scents, dyes, outdoor formula, etc. Just plain 'ole bleach.
    If you are close to a pool store that sells "liquid Chlorine" in a big jug, you may be better off that route. Its usually the 12% stuff, so compare price by volume to see if its a good deal.
    Have you put any algecide or clarifier in? I know the non Poly 60 algecide will cause foam. Clarifier will cause cloudy water if over used. (I know from experrience on both counts)
    Nater
    As the algae and organics break down it is normal to have some foaming occur. Sicne the water is still cloudly and you still have CC I would say you just have not finsihed dealing with the stuff in your pool. The foam should go away once the water clears and the CC goes to 0. Just keep the chlorine levels up and give it a bit of time. "regular scent" bleach ususally means that the bleach has no scent additives and is just plain chlorine bleach so that should not be the problem.
    Thank you both for your prompt replies. I will keep chlorinating the pool until I see CC = 0. Any idea how long will it take for the water to clear once CC reaches 0? Once CC reaches 0, do I need to keep chlorine at the shock level? Thanks!!!!
    By the way, I have not used any algecide or clarifier...
    I would keep it there until the water clears or at least until your FC is holding steady. It might take up to a week longer for your filter to clear the cloudiness out of the pool if it was the start of an algae blooom.
