Results 1 to 3 of 3
Thread: TA differences
    Jul 2006
    Default TA differences
    I test my TA with a Taylor 2006 kit, and it was 160 on Apr 22nd, so I lowered my PH, and run the pume with the nozzles as far up as possible. It is not doing as much airation as I would like, but I thought it would over time, running the pume 24/7. Yesterday I tested with these results:
    FC 9.5
    CC 0
    PH 7.2
    TA 110
    CA 260
    CYA abt 25
    I have been adding Triclor to keep FC at about 19, and boost the CYA just a bit to get to abt 30.
    Pool is Plaster.
    My question is this... My TA tests say 110. I took some water to a new Hardware store with a computerized testing setup, just to see how we compare. Their results are:
    FC 9.6
    TC 9.6
    CC .0
    PH 7.4
    CA 160
    Alk w/ stabilized correction: 0
    CYA 25
    Why do they show 0 fro Alk, and I show 110?? She run the test 2 times??
    I also came home and run a alk test with a different test kit (bought at walmart last yr), and still got about 110.
    Les
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: TA differences
    Quote Originally Posted by hooeld View Post
    FC 9.5
    CC 0
    PH 7.2
    TA 110
    CA 260
    CYA abt 25
    Pool is Plaster.
    FC 9.6
    TC 9.6
    CC .0
    PH 7.4
    CA 160
    CYA 25
    Les
    Are they using the LaMotte WaterLink Express/Datamate software system with the little vials that they inject the water in and then read them in the colorimeter? If so then I know what is happening. The TA test in that system will read low if the FC levels are 10 ppm (or in that general area). That is a documented interferance that any LaMotte certified operator would know about. Ditto for the differences in the CH and pH tests. The powdered reagents that LaMotte uses seem more prone to bleachout or interference at high chlorine levels than the liquid reagents that Taylor uses. I would suggest waiting until your FC drops a bit and then checking the test results. The LaMotte chemisty is accurate but it's little quirks do need to be taken into account (The Taylor chemistry has it's own little quirks that can give inaccurate results also!)
    Edit: Also, it seems that LaMotte recently had a batch of TA unit dose vials that were not good. We had to return some to our supplier because they were all showing very low TA. The replacement ones we got did not have the problem. Once again that type of thing can happen with ANY manufacturers testing supplies.
    Jul 2006
    Thanks Waterbear.. That makes sense..
    It was the type tester you mentioned..
  1. Differences in Vulkem sealants?
    By booztedgt in forum In-Ground Pool Construction and Repair
    Last Post: 07-09-2010, 11:32 PM
  2. Solar Blanket Differences?
    By NullQwerty in forum Pool Equipment & Operations
    Last Post: 06-10-2008, 09:20 AM
  3. Differences in test kits
    By CanuckPool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-13-2007, 12:38 AM
  4. Dolphin diagnostic advantage-differences?
    By luvapool in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-27-2006, 12:26 PM
