Results 1 to 10 of 10
Thread: CYA Reagent
    drumr is offline ** No working email address ** Thread Analyst drumr 0
    Gordonsville, Tn.
    Default CYA Reagent
    I have an Aquachem test kit (Wal-mart) and need just the CYA reagent. I couldn't find just that reagent for the Aquachem and was wondering if anyone knew if they were all the same. Could I get the reagent from Taylor and it work with the Aquachem setup. I believe I am using a 25 ml sample and probaly another 25 ml of reagent then into the tube of the dissappearing black dot.
    Thanks,
    JD
    Default Re: CYA Reagent
    Quote Originally Posted by drumr View Post
    Thanks,
    JD
    As far as I know, it's all the same stuff. I've bought CYA reagent at Leslie's that has worked just fine with both Ben's kit and with the Aquachem kit. Take a look at your instructions for the Aquachem kit--if there is an 800 number there, it would be worth calling it. Other members of the forum have posted that by calling the Aquachem number on the kit, they in the past have sent replacement reagents, sometimes free of charge.
    our WM is selling the HTH kits now instead of Aquachem. There is only enough reagent to do 2 tests. More will need to be ordered. They sell replacements for the PH and OTO but never the CYA, thats the one that I need replacements for most often and end up buying a whole kit just for that.
    You can use the Taylor CYA reagent with the Aquachem kit or the HTH kit with no problems.
    Gordonsville, Tn.
    Thanks everyone for your responses. I will order some taylor reagent. I just bought this kit and have never actually tested my pool for CYA so when my first test came out zero I thought I did something wrong so I did it again and came out 0 again. I put some stabilizer in and now I am at 35. NWMNMom stated that you only get 2 test out of it, I got 4 out of this one, but now I am out.
    JD
    catnip is offline Registered+ Thread Analyst catnip 0
    Blue Mountain Beach, FL
    AquaChem will replace the reagents if you call them (actually sent an entire new test kit). Just call the number in the guide that came with the kit. You may need to be persistent as they had some QC issues between the service support folks on the phone and the fulfillment warehouse. It took me three calls and a discussion with a manager who admitted the shipment issues. But, I got a new kit the next day by overnight delivery!!
    On the other hand, I suggest you consider a "better" kit. I upgraded to the Taylor K-2006 FAS-DPD and found that TA and CH were MUCH easier to measure with definite end points. In my case at least the AquaChem was essentially worthless on those two measurements. You also get more precise and higher range FC readings.
    In either case you will need extra CYA reagent if you want to do more than a few tests.
    Chuck
    16,000 gallon gunite/plaster, Pool Pilot Digital SC-60, Pentair UltraFlow 1 HP pump, Pentair Tagelus TA 60 filter, Polaris 280
