Thanks for the link.
Jeffski,
I'd recomend this Salinity test kit from Taylor (or a similar kit from someone else) Since the SWC measure conductivity the actual salt level vs. screen reading can be different by several hundred ppm due to several factors. I use this kit to calibrate my autopilot as needed.
Also, the experts tend to agree that the salt test strips are accurate enough for our purposes, if you can find those instead.
http://www.taylortechnologies.com/pr...=-1&KitID=2176
Nater
Whatever the results say, put in considerably less, test, and add as needed. If you put in too much, it's work to get the level back down. Better to err on the side of not enough, and add a little bit at a time.
Jeff
Keep notes on how much you add and what the change is - that way in the future you'll know how much salt to add to raise the level 500 ppm (ex)![]()
Thanks for your help. I have continued this discussion and appreciate your feedback here:
http://www.poolforum.com/pf2/showthread.php?t=4969
