Re: Can't get the green out...
I haven't test my CYA this year because I'm out of the stabalizer solution - I can't find refills
Any suggestions?
Order Reagent 0013 on-line from either Leslie's on-line service or Taylortechnologies.com
In fact, you can order anything and every combination of test kit from either. You can even build your own.
The Taylor K-2006-C is basically the same thing as Ben's PS-234. The Leslie's FAS-DPD Chlorine Service Test Kit is nearly the same--my only suggestion is to augment that with the Taylor/Leslies OTO test kit that uses Reagent 0014 for the pH test--it's got chlorine neutralizer in it so higher chlorine levels don't skew the test.
Even with an Intex either will pay for itself in NO time!
