Results 1 to 1 of 1
Thread: Inconsistent Readings
    Guelph, ON, Canada.
    Default Inconsistent Readings
    Two weeks ago, in preparation for spring start-up, I reached under my mesh cover, and took a sample using last year's K-2005 test kit.
    Values were
    FC-0
    TC-0
    pH-7.2
    TA-0
    CYA-0
    CH-20
    I was expecting TA, CYA, and CH to be about 25% lower than last years closing due to melted snow. So I didn't believe the TA, CYA, or CH readings. So I measured three times re-read the measuring instructions and got the same results.
    My first guess was that the reagants had gone bad, and I'd have to pick up some more. I didn't get around to it, but when when I was in the hardware store I picked up some test strips to confirm if my tests were off. The test strips provided similiar results.
    Today, I removed the cover, connected the pump and started cleaning up the water. Still hadn't picked up the reagants so I thought I'd have to go to pool store to get sample measured. But first I tried my own measuremnts using last years test kit.
    Cl-0
    pH-7.2
    TA-100
    CH-250
    CYA-40
    Test strips measurement was reasonably close to same values.
    The water tests for both the K2005, and the strips changed significantly. So the issue is not my test kit reagants .
    Question #1
    Any idea why the difference between measurements 2 weeks ago and today?
    I have two guesses, but neither seem plausible to me.
    My first guess is tests provide accurate results above a specific water temperature. First reading performed at water temperature around 45F, today water temperature was 55F.
    My second guess is that the pump/water circulation had an affect. Is the CYA or TA low at the water surface after a long winter. If so, vacuuming would have circulated the water around to be more uniform?
    Question #2
    Do I need to replace all the reagants every year or just some?
    __________________
    Carl Schnurr
    96,000 litre, vinyl liner, 1.5 HP 1speed pump, sand filter, SWG, installed 2005.
    Carl Schnurr
    96,000 litre inground, vinyl liner, 1 HP 1speed pump, sand filter, SWG, installed 2005.
