Whenever chemicals don't do what you expect, it always casts doubt on your test results. Some pH test methods are inaccurate at high chlorine levels. A pool store test would be a good sanity test right now.
A good way to figure out what's going on is to take a 5 gallon bucket of pool water and experiment. A cup of borax ought to make a big difference in the pH of that bucket of water. If it doesn't, try it again with tap water. That ought to give you an idea of what is happening.
You want the alk between 80-120.
