Results 1 to 10 of 11
Thread: 5 Boxes of Borax later.... PH STILL very low
    Michigan
    Default Re: 5 Boxes of Borax later.... PH STILL very low
    Ok one thing I totally forgot till I was outside, was that last night around 6 p.m. we added one jug (I believe 6 pounds) of stablilizer. Then we've had the filter on since then. Would that cause a temp drop in PH?
    Why BBB? Because money can't buy happiness, but saving it sure can!
    Yes. Stabilizer is highly acidic. It's Cyanuric Acid and is literally an acid and it's strong enough to show a serious drop in pH with the amount you add. It also dissolves slowly so you'll be fighting this drop until it fully dissolves.
    Every pound of stabilizer will require about 1.3 pounds of 20 Mule Team Borax to maintain pH.
    Richard
    Michigan
    So I'll just keep adding Borax daily for the next few days until I get the stablilizer all dissolved. I better inform Meijer that they don't stock enough of it to meet my pool needs.
    Since we just got a new liner last thing in the fall before we closed, I was worried I was off to a poor start this spring. Sounds like I'm OK for now after all.
    Thanks so much guys!
    mbar's Avatar
    Ashland, PA
    Your alkalinity is a little high, so you can also turn your return jets up so that the water bubbles on top - it will raise your ph while lowering you alk. killing two birds with one stone You want the alk between 80-120.
    Northeast PA
    Excellent suggestion Marie! Only add enough Borax to keep the pH around 7.0 if the aeration isn't enough to keep the pH there all by itself.
    Michigan
    Well crap, I thought Borax wasn't supposed to increase the alkalinity much.
    I fought that vicious circle back when I used pucks.
    PH low, raise ph. Find alk too high, add acid. PH low, raise ph. Find alk too high again. etc etc etc
    Turning the jets up sounds easy enough, but won't that affect the way the pool gets circulated?
    Edit: also, how can you aerate that way when you use a solar cover?
    Quote Originally Posted by doggie View Post
    Well XXXX , I thought Borax wasn't supposed to increase the alkalinity much.
    It doesn't. But T/A moves up and down with pH. As pH goes up, so does T/A.
    Part if it was not understanding the mechanism. T/A rises and falls with pH. Soda Ash, however, increases T/A MORE than that rise-and-fall ratio. But Borax, which only increases pH, doesn't prevent the rise-and-fall.
    Only aeration can raise pH without raising T/A.
    Not too much. You don't HAVE to turn up the jets--it just makes aeration go faster. So will a crowd of 10-12 year old boys turning your water into a maelstrom!
    You can't. Sorry about that, but get your chemistry correct first, before trying to warm the pool.
