Results 1 to 10 of 11
Thread: 5 Boxes of Borax later.... PH STILL very low
    Michigan
    Default Re: 5 Boxes of Borax later.... PH STILL very low
    Well crap, I thought Borax wasn't supposed to increase the alkalinity much.
    I fought that vicious circle back when I used pucks.
    PH low, raise ph. Find alk too high, add acid. PH low, raise ph. Find alk too high again. etc etc etc
    Turning the jets up sounds easy enough, but won't that affect the way the pool gets circulated?
    Edit: also, how can you aerate that way when you use a solar cover?
    Why BBB? Because money can't buy happiness, but saving it sure can!
    Quote Originally Posted by doggie View Post
    Well XXXX , I thought Borax wasn't supposed to increase the alkalinity much.
    It doesn't. But T/A moves up and down with pH. As pH goes up, so does T/A.
    Part if it was not understanding the mechanism. T/A rises and falls with pH. Soda Ash, however, increases T/A MORE than that rise-and-fall ratio. But Borax, which only increases pH, doesn't prevent the rise-and-fall.
    Only aeration can raise pH without raising T/A.
    Not too much. You don't HAVE to turn up the jets--it just makes aeration go faster. So will a crowd of 10-12 year old boys turning your water into a maelstrom!
    You can't. Sorry about that, but get your chemistry correct first, before trying to warm the pool.
    doggie,
    If you believe that your TA used to be lower and that it has gone up, then as Carl says that wouldn't have come from the Borax. Most likely, it came from your fill water. Is your fill water from a well? Have you tested it for TA and CH? That's my best guess of what may be happening. In any event, Marie is absolutely right that now is a great time to lower the TA since you've already got a slowly dissolving acid in your pool and that's perfect for lowering TA through lots of aeration.
    Richard
    doggie,
    Richard
    Richard's right. My fill water, which is public water, frequently runs a T/A of 180ppm--safe to drink, of course. You should check it.
