Quote Originally Posted by bbse View Post
Yes, I bought 80lbs of Trichlor at Sam's last year but it has stabilizer in it at since my pool is already up to nearly 70 ppm of CYA, I want a source of chlorine that does not have CYA added to it.
Doing the same here. Due to the SWG I need the -PH from the Trichlor and my CYA is low after every winter.
I use trichlor sparingly for extra boosts in chlorine and when CYA or Acid needs a bump.
Consider the cost of Acid and Stabalizer the Trichlor really works out to be a great value in my situation.
I think as long as you keep an eye on your PH and CYA the trichlor is a clear winner.
