Results 1 to 10 of 22
Thread: Polyquat or not ?
    Rbrenton is offline ** No working email address ** Rbrenton 0
    Default Re: Polyquat or not ?
    Hello all, sorry to open up an older thread, but I too open up a NJ pool to pea soup every year using a mesh cover. A friend insists that their pool is crystal clear in the spring because they use a solid tarp under the mesh which is designed to use the mesh cover's anchors.
    I can't see how this would impact green algea, but I don't know what chemicals are used by their closing company. Mine apparently doesn't do much, but I'm never around when they show up in early October.
    Does anyone have an opinion on what this solid layer is capable of?
    Michigan
    Quote Originally Posted by Rbrenton View Post
    We also have a mesh cover and opened to a crystal clear pool. The 2 things we did were 1st: we opened in early May before the water had a chance to heat up too much (we are in West Michigan). And 2nd: we used a Keeper Klean on the water which prevented sunlight from getting in. http://www.poolproducts.com/-c-FCATHPIKKC-FNM-92.htm
    I'm not sure which one did the most good, or maybe a combo of both, but from now on we'll always use this method.
    Why BBB? Because money can't buy happiness, but saving it sure can!
    Has anyone been told to use an enzyme called "pool magic" at closing to prevent algae growth? My neighbor uses it and he said a few pool stores recommend it in addition to algaecide.
    I was only planning on shocking with liquid followed by polyquat before I blew out the lines and covered. Any thoughts or experience on using or not using pool magic at closing? Or if I'm using Polyquat is that enough?
    FYI I'm using a mesh cover on a 24K gal vinyl pool in ROC NY.
    Andy
    According to this link, this enzyme product will break down organics to help prevent scum lines, but it says nothing about killing algae. Technically, enzymes are catalysts and simply accelerate specific chemical reactions, in this case the breakdown of organics by chlorine (or, to a lesser extent, dissolved oxygen if there is no chlorine left). Though technically algae is organic, I don't think this product will do much good at killing algae faster than it can reproduce, but it might speed up the breakdown and clearing of already killed algae IF chlorine is present.
    So chlorine is really the key to having the enzyme work effectively -- it can be thought of as a "chlorine helper".
    The bottom line is that I don't think this is particularly helpful for winter closing unless you have a modest amount of organics (i.e. leaves, etc.) fall into your pool and have both chlorine and this enzyme to break them down more quickly. The PolyQuat is a better choice for preventing algae, though simply regularly adding chlorine will work as well -- probably only once a month or even less since at cold water temps the chlorine lasts a LONG time.
    Richard
    Chem Geek,
    Thanks for your reply. Based on your assessment, I'm going to go with straight Polyquat 60 and chlorine. In the spring we'll see whether my two neighbors (that used Pool Magic) have clearer water or not.
    Andy
