Drain line issues!! HELP
Hi All,
Recently started to drain the pool for a soon to happen vinyl liner replacement. The pool draining was going fine.
I got about 3/4 or more of the water out and had been draining through the bottom drain and out the backwash of the filter.
Two days ago, the pump lost prime. Reprimed, restarted and no go.
I have shot water down from the pump side and see it push air out of the floor drain. Ran a snake up from the bottom as far as I could and seems to be open.
Filled line with water from pump side and started. Pump is working as it sucks all the water out of the basket and pipe, but then goes dry. After it is dry, there is a ton of sucktion trying to remove basket cover.
What should I do??? Do I have a clogged or broken waist line? How do I tell / fix???
Scott
