Results 1 to 10 of 11
Thread: Whick Kit?
    Lafayette, La
    Question Whick Kit?
    I have run out of reagents in my test kit- ordered from Taylor this past weekend - I am in the midst of attempting to clear an algae bloom- The walmart HTH 5 test kit does not test for free chlorine or CC- What other kit is out there to get- Leslies has some kit DPD but only reads chlorine to 5 ppm- Help Please!
    Indiana.
    Default Re: Whick Kit?
    Dilute your pool water sample with distilled water. Mix 3 parts distilled water to 1 part pool water, test the mixture, then multiply the reading by 4.
    You can buy, either from TaylorTechnologies or Leslies, just a FAS-DPD Chlorine test kit that tests FC and CC up to 50ppm. This is the key to Ben's PS-234, Taylor's K-2006C and Leslies FAS-DPD Chlorine Service test kit. You can buy JUST that for about $20 and super-charge your HTH kit.
    Lafayette, La
    Smile Re: Whick Kit?
    Thank you for your help on my way back to Leslies
    Quote Originally Posted by grangerhj View Post
    Oops...the store probably won't have it, but you can order it online easily. I don't know if the store can order it for you.
    Also, be prepared for the clerk to look at you as if you are speaking Patagonian when you talk about FAS-DPD testing.
    Lafayette, La
    You were quite right- the clerk thought I was speaking a foreign language- anyway I purchased their DPD kit- I figured that it was better than nothing and I could subract free chlorine from total to get my CC. My problem of course is that the calibrations are to 5 ppm- if I add 3 parts distilled water to one part pool water and multiply x 4 that is still only getting me to 20 ppm- I have been trying to stay above 20 to kill an algae bloom that I have been battling since Sunday. So 9 parts distilled water to 1 part pool water and multiply by 10 appears to be my only option (am I right?)- Any other suggestions?
