Thread: first year on BBB
    Default Re: first year on BBB
    PH needs adjusted first to ideally between 7.4-7.6, although anywhere between 7.2-7.8 is OK. Also, you need to get your chlorine level to an appropriate level based on your cya reading. You can actually work on your cl and your ph at the same time. I do it all the time. Most of us agree that cya between 30-50 is fine and thus your chlorine should be maintained between 3-6 ppm. A good TA reading is typically between 80-125. Hope this helps you get started.
    Jul 2006
    Connecticut, USA
    Exactly what I needed . THX
