Thread: Suction Side Air and leak
    Kansas
    Default Re: Suction Side Air and leak
    One more question before I dig. I came across a page somewhere on the internets where it was advised if you have a robot, you can just abandon the main drain period. The robot run religiously will circulate enough from the bottom.
    Good idea, bad idea?
    Thumbs up Re: Suction Side Air and leak
    The robot will provide some extra circulation for your deep end. Is it a good substitute for the MD, but a designated line to pull that lower water is better. (JMO) There are other options, I mentioned 1 of them in my earlier post (about the 'reserve line). It helps to have the water in the deep end moving around - the robot will 'at least' stir things up down there.
    Let us know a little more about the 'suction/ return' system on your pool - another idea might just come
    Kansas
    I have just a main drain in deep end, skimmer also located on side in deep end. Two return lines, one 3/4 way down on long side, the other located just before the curve on the end straightens out, opposite of the 1st return line.
