Results 11 to 12 of 12
Thread: Oto Test Kit Question
    Default Re: Oto Test Kit Question
    Quote Originally Posted by sisie5
    Carl,what are pucks?and how do you use them?Thanks for a quick responce
    The pucks that Carl was referring to are trichlor pucks, which have a very low pH and also contain a good bit of stabilizer. There are feeders made for them, or you can buy a floating dispenser that allows them to dissolve slowly, releasing chlorine and stabilizer into your water. Some people put them into the skimmer to dissolve, but if you do that, make sure that your pump is running all the time so your pump doesn't get a huge dose of low pH water that has built up in your skimmer overnight. Just be careful where you buy them....hth has changed its formula, so the ones at WalMart are labeled "dual action", but contain copper, which you don't want in your pool. If you decide to use the pucks, check the ingredient label and make sure that they don't contain copper.
    Floaters are great for pucks--they cost about $10, where an in-line chlorinator costs a lot more-- and I don't see how they are any easier to use.
    And since I don't recommend perpetual use of pucks, I don't see the point of plumbing in in-line chlorinators.
  1. CYA test question
    By oasisdave in forum DPD-FAS based testing
    Last Post: 07-14-2006, 08:10 AM
  2. First test and a Question
    By vchords in forum DPD-FAS based testing
    Last Post: 06-20-2006, 03:55 PM
  3. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
  4. CC test question
    By GolfTop in forum DPD-FAS based testing
    Last Post: 06-06-2006, 12:36 PM
  5. 233 kit - CYA test question
    By vanhout in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-17-2006, 10:21 AM
