Results 1 to 8 of 8
Thread: Water Hardness 498
    Scottsdale, Arizona
    Default Water Hardness 498
    What do I do to get the hardness down
    Default Re: Water Hardness 498
    I would add that you should test your fill water and if it has a similarly high CH level, then the only other option is to use a water softener, but it's a huge task for a large volume of water (i.e. would need lots of recharging frequently). Well water is often high in CH and some people have "whole house" water softeners. If you get a pool with an initial CH that is good, but have fill water with high CH, then using a water softener on the fill water is reasonable -- but for an entire pool with already high CH it's difficult.
    Richard
    Where did you get a test reading of water hardness 498 ppm? It's sort of a strange number for a hardness test, even when a colorimeter is used. Is that for total hardness or calcium hardness? If it is total hardness then your calcium hardness might not be too high at all.
    Yes, if you drop test you'll get 490 or 500ppm, not 498.
    Test it yourself to be sure.
    Scottsdale, Arizona
    It is Total Hardness.
    I have to admit to allowing a Pool Store to test my water (i'm ashamed). I was going in to buy a new floaty chair and decided to take in a sample to calibrate my Salt Test . They use the test strips/computer system.
    Other than adding a little Baking Soda for the TA the water is balanced. The hardness jumped out at me.
    It was a new fill last summer and our city water is naturally hard. I guess I'll live with it.
  1. What is hardness?
    By jerome in forum Dealing with Alkalinity and Calcium
    Last Post: 05-08-2012, 12:45 PM
  2. Replies: 5
    Last Post: 12-04-2007, 11:22 PM
  3. OH (Ohio) Water Hardness/ph -- Adding chems while filling?
    By rydeacowboi in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2007, 07:17 PM
  4. Who is correct: Water hardness test
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2006, 12:21 AM
  5. Water hardness?
    By HAYMAN in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-18-2006, 12:05 AM
