Thread: stains on pool
    Default stains on pool
    i have brown stains scattered over the bottom and sides of the pool. most likely iron stains. (i have posted this in my previous posted under Using Chlorine and Chlorinating Chemicals section). you guys said you could walk me thru how to get rid of the stains. would you please advise me. Thanks.
    Default Re: stains on pool
    Quote Originally Posted by poolhelp101 View Post
    i'm not getting any responses from this or the other post concerning the numerous stains... i don't know why but anyway, would you please tell me if what Mbar has said in the "What is cheapest online source of ascorbic acid?" post is what i can do to rid my pool of the stains?
    i sure would appreciate some guidance. thank you
    mbar's Avatar
    Ashland, PA
    Hi,
    Here is the ascorbic treatment:
    Here are the directions:
    Take your chlorine down to 0, if there is chlorine in the water it won't hurt, it will just eat up the ascorbic acid, so you will need more to get rid of the stains.
    You will need about a half to one pound of ascorbic acid per 10,000 gal. I like to go lighter on it and see if all the
    Put the filter on circulate.
    Use a cup and go around the perimeter of the pool and drop it down the sides as you go.
    Let the ascorbic acid circulate for 1/2 hour. You will be amazed how the stain just disappears before your eyes.
    If the stain is not all gone, leave the filter in circulate and add more ascorbic acid close to where you still see stain. Leave it in circulate until all of the stain is gone. (add more ascorbic acid if it circulates for 1/2 hour and there is still stain)
    When the stain is gone, add enough sequestering agent for the volume of your pool - more is better than not enough.
    Put the filter back on filter and leave it on 24/7.
    The ascorbic acid will bring your ph down, after 24 hours you can start to bring up your ph and alkalinity - use baking soda first, it will raise both ph and alk. Make sure you test in between, because you don't wantyour ph to go any higher than 7.2. If your alkalinity is in range, and you still need to raise your ph, use Borax to take it up to no higher than 7.2. After 48 hours you can start to bring up your chlorine. You want to do this slowly. It will take a lot of chlorine - I prefer to use bleach only at this time, and try to take it up to your minimum chlorine for your cya according to the "best guess chart" Do not shock! Do not shock for at least 2 weeks! Make sure you keep your ph low for (7.2) for a week or two - it won't be hard because the ascorbic acid will help it stay low. Once your chlorine starts to hold, it means that you have used up the ascorbic acid in the water and it will be easy to rebalance the pool back to your regular parameters. You may want to use a polyquat algacide as a deterrant to getting algae while your chlorine is low.
    Here are ascorbic acid links:
    http://www.msm-msm.com/store/agora.c...scorbic%20Acid
    http://www.chemistrystore.com/Ascorbic_Acid.htm
    Let me know if you have any other questions
    Northeast PA
    Western NC
    Just to clarify, does one need to keep the filter running 24/7 throughout the week or two process?
    mbar's Avatar
    Ashland, PA
    You don't have to keep it running 24/7 for all two weeks. I would keep it running all the time till you start to bring your chlorine up, which would be after 48 hours. If the water is cloudy, sometimes it gets cloudy with the treatment, then keep it running 24/7 longer.
    Northeast PA
    Western NC
    Thank you!
