Thread: First Test Results
    Jul 2006
    Default First Test Results
    My Taylor K-2006 came today and here are my results. Some suggestions would be greatly appreciated. The water is fairly clear/slightly cloudy. The pool was opened Monday.
    FC=1.4
    CC=4.0
    pH=7.2
    CYA=<30 (I could see the dot but was cloudy)
    TA=110
    Temp=82
    25,000 gal IG vinyl
    25,000 IG vinyl Utopia pool
    Jul 2006
    Default Re: First Test Results
    Did you run your chlorine tests more than once? I'd be a little suspicious of a CC reading of 4 unless you had a major swamp. Maybe retest again and see what you get.
    Retest this AM...
    FC=4.8
    CC=0
    I was not looking down into the tube last night...last night I added three pounds of CYA
    CYA=30
  1. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  2. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  3. First test results
    By poolbee in forum DPD-FAS based testing
    Last Post: 06-15-2006, 11:27 PM
  4. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 08:30 PM
  5. first test results
    By jazzbone in forum DPD-FAS based testing
    Last Post: 05-26-2006, 04:19 PM
