Re: ph control, Am I adding acid to often
Bill - I don't think what you're going through is that unusual at all. My IG with Pebble pool was finished in August 2006 and I've been having to add 1-2 pints of acid every couple days just to keep the pH under control.
You should start seeing the pH rise less quickly, however - from what I've read, it could take 6 months or even longer for the pH to stabilize.
One thing you might consider is adding some borax to your pool. Have you seen this thread http://www.poolforum.com/pf2/showthread.php?t=4712? Borax adds borates in your water and it acts as a pH buffer. I did that to my pool about a month ago, and now my pH is more stable and have to add acid only once a week.
