Closed Thread
Thread: hydrostatic pressure
    Default Re: hydrostatic pressure
    Did it blow out or blow in? Was there an increase outside pressure or a drop in outside pressure?
    OK
    Cool Re: hydrostatic pressure
    If it was full at the time, I'd say you had some erosion from underneath the pool. If you pumped ground water from the sump pit located under the pool, some sand may have been washed out with it, leaving an area with no support for a pool full of water.
    If it was empty at the time, I'd say external pressure from ground water was to blame.
Closed Thread
  1. Hydrostatic relief valve
    By OOsever in forum In-Ground Pool Construction and Repair
    Last Post: 06-15-2012, 12:03 AM
  2. Draining your Pool and Hydrostatic Pressure
    By Trition in forum In-Ground Pool Construction and Repair
    Last Post: 01-27-2011, 04:46 PM
  3. Problems with Hydrostatic Valve
    By PatG25 in forum In-Ground Pool Construction and Repair
    Last Post: 05-18-2010, 02:21 PM
  4. Hydrostatic Plug
    By ellry99 in forum Pool Equipment & Operations
    Last Post: 06-24-2006, 04:17 PM
  5. hydrostatic valve leak
    By millpool in forum Pool Equipment & Operations
    Last Post: 05-12-2006, 11:53 PM
