Results 1 to 10 of 12
Thread: starting conversion ???
    Thumbs up Re: mid way through conversion something happened??
    day 1: soupy green with floating stuff, added 4-gallons of shock (thurs)
    day 2: dirty green cant see bottom added 4more gallons shock 12.5% tested with strips thats what i have money thing, did buy wally world 6-way but seems weird to me.(friday) tested it, was like copper orange???
    day 3: (Sat morn) woke up, vac bottom of pool for a hour couldnt see bottom but i knew there was stuff on the bottom, went to work for 8-hours had the wife test h20 was at 0 added 4-gallons shock, at four hours later she tested water was 5ppm had her add 2-more gallons to get it to 10-15ppm, its now 6pm Im home from work.(sat)
    Didnt know what to expect dirty green water?? Add more shock?? Oh may G-d
    something transformed when i was gone the water is almost clear i mean clean!!!!!! Vaccuumed all the scum on the bottom, then Im running my barracuuda for a couple of hours, I cant believe its clear, really Im like a kid in a candy store. Ill test when i go to bed and also sunday morn, so now what do i do, besides looking at clear water Hay!!!!!!!!
    Default Re: mid way through conversion something happened??
    When you can shock at night and have pretty much the same chlorine level the next morning, you are home free. After your conversion, you'll need to change your filter media.
    Default Re: starting conversion ???
    glad to here from u:
    Iknow about the filter change, any insight about the next step for chemicals, its cold right now 50 i didnt think it would clear so fast, so to keep it clear thats all about chorine, right also with the other stuff.
    After you get to the point where you are no longer losing chlorine overnight, you'll need to post current water testing results. Ph, Alk, cl. Obviously, you won't have any cya yet. That will be something you'll need to add. Post some current numbers and somebody can help you.
    Question Re: starting conversion ???
    sunday morn chorline reading around 5 it was 15ppm at 10pm last night,do i want it back to 15ppm, and hold 15ppm through out the day and through the night till morn?? sorry a little confused
    Quote Originally Posted by larry b View Post
    Yes, you want it back up to 15, and keep it there until it's still at the 15 throughout the night and into the morning. Hang in there, you're almost there!!
    Wink Re: starting conversion ???
    thanks alot, Im back home tested water its back to 5ppm added 2-gallons 12.5% shock to get to 15ppm, will test 10pm and also in the morn, 16 gallons into the conversion, even if the water is very clear i must still have some baq, in the pool is that correct, will need some more gallons for monday-friday keep on shocking
