Results 1 to 10 of 12
Thread: starting conversion ???
    Default Re: mid way through conversion something happened??
    When you can shock at night and have pretty much the same chlorine level the next morning, you are home free. After your conversion, you'll need to change your filter media.
    Default Re: starting conversion ???
    glad to here from u:
    Iknow about the filter change, any insight about the next step for chemicals, its cold right now 50 i didnt think it would clear so fast, so to keep it clear thats all about chorine, right also with the other stuff.
    After you get to the point where you are no longer losing chlorine overnight, you'll need to post current water testing results. Ph, Alk, cl. Obviously, you won't have any cya yet. That will be something you'll need to add. Post some current numbers and somebody can help you.
    Question Re: starting conversion ???
    sunday morn chorline reading around 5 it was 15ppm at 10pm last night,do i want it back to 15ppm, and hold 15ppm through out the day and through the night till morn?? sorry a little confused
    Quote Originally Posted by larry b View Post
    Yes, you want it back up to 15, and keep it there until it's still at the 15 throughout the night and into the morning. Hang in there, you're almost there!!
    Wink Re: starting conversion ???
    thanks alot, Im back home tested water its back to 5ppm added 2-gallons 12.5% shock to get to 15ppm, will test 10pm and also in the morn, 16 gallons into the conversion, even if the water is very clear i must still have some baq, in the pool is that correct, will need some more gallons for monday-friday keep on shocking
    Yes, you still either have some Baq or something else trying to grow in the pool...that's why your chlorine keeps dropping. Get some more bleach, keep shocking until your Cl level holds steady overnight.
