CYA increase
Hey Gang,
I'm back from last year. I just put my pool back up, filled it up, and added my bleach.
My CYA is below 30...probably 0 as it was quite clear.
My question is....since I switched over to BBB midseason last year, I have lots of 3" chlorinating Tablets (Trichloro-s-Triazinetrione) left. Can I use them to raise my CYA? If so, how would be the best way. Or do I need to go buy CYA?
I live in Central Texas where the sun shines Hot today and only gets worse as the summer moves on. I figure I need to have some CYA so that I'm not dumping galllons of bleach a day into the pool.
Thanks for the help. This list is the best!
Centexpool
15x42 Above ground Intex, with 130 lb Dougboy sand filter 3/4 hp pump.
4646 gallons
