Re: water draining from filter
Thanks. My DH doesn't think that the crack in the pump is a problem-he says it is just the motor housing but I'll post a pic if I can figure out how.
We really REALLY lubed up the pump basket seal and filter o-ring and things seem to be holding for now. I am going to get new o-rings for both and see if that will work. Hasn't been any more water visible from the waste pipe so I'm hoping new rings are all it needs and I opened the waste valve and closed it to make sure it was tight. I did put Gorilla tape over the pump crack too-just incase.
I am also wondering if the filter bleed valve could be a source. Are those replacable?
