Re: water draining from filter
Poolbee:
I have leak in waste pipe and around the clamp on my Jandry filter. There is a threaded pipe which is the waste pipe that is joined to a coupling. When I tighten one both move. If I trun one to the left will they both come off so I can get to the o ring? My seal on the clamp is about two yeasr old .Looks OK but really have to tighten to stop leak. Im wondering if I should get a new one or just lube it? I have DE laying at the bottom of pool. Does anyone know if the leaking waste pipe could because of this?
Can anyone help me out with one of the return eyeballs It appears the threaare stipped where I screw it inot the pool becaue I tried screwing two different ones in and they get blown off.. Can I run filter without the eyballs?
16 x 32 plaster in ground.
Thanx in advance for any help.
