Re: CYA and Lifetime of Chlorine
Do you think a small experiment using a bucket of water, < 3 Gallons, and small amounts of CYA and chlorine would be valid and applicable to a swimming pool? To experiment with a pool is difficult to control and can be expensive as well so I though perhaps a reduced size experiment might actually measure the results you presented. One could measure the CL loss over a 24 hour period for varing amouts of CYA. To me, this would be fairly definitive and perhaps show a significant increase in retention going from 60 to 80 for which current understanding has not accounted for.
However, it wouldn't actually tell us much about SWG operation but if people without SWGs are seeing improvements when raising CYA from 60 to 80, then perhaps what is happening has less to do with SWGs and more to do with binding properties of CYA.
