Any alternative to acid wash?
A large number of white stains have accumulated on the bottom of our pool over its nearly 20 year life span. Since the plaster is dark blue these are rather unsightly.
I assume the stains are due to numerous bags of calcium hypochlorite having been sprinkled around the edge of the pool over the years and further calcium deposition due to periodic high pH following poorly controlled pool chemistry. For the last year at least I have predominantly used liquid bleach and controlled the water chemistry myself, so I hope they will not get any worse.
Three years ago the pool was acid washed. Since the pool is large (approx 30,000 gallons), the acid process was a major job and the sight of clouds of hydrogen chloride gas wafting across my yard was somewhat disconcerting. Also the job was not a great success because while some of the more unsightly stains were removed many still remained. I had not seen an acid wash performed before, so I can’t tell whether this was just an unprofessional job or the stains were particularly stubborn or acid wash was the wrong approach, but it seemed a like a lot of risk for a small return. Also emptying and refilling the pool is a major hassle (flood running down hill in neighbor’s yard during emptying and several days of refilling from well with lots of metal in water). Of course there are ways of mitigating these issues (fill from tanker etc), but I would prefer a less drastic approach if possible, even if it takes all summer.
Any suggestions on how to identify the stains, determine what is the best way to remove them and whther it is possible to do this without draining the pool?
- You may not post replies
- You may not edit your posts
Forum Rules
