Thread: im getting there
    dallas, ga
    Default im getting there
    found this site last year, read everything i could, closed the pool by this forum, water clear, cl little low 1.3, ph 7.6,alk 110, cya 30, im still confused about reading on cl, how do i get the fc reading, i do have the walmart 5-way, ag 13500 gal
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    Default Re: im getting there
    I don't think the walmart test gives you a free chlorine reading and a combined chlorine reading. I think it says the first reading is your fc, and you wait a little, then read it again - that will give you a combined chlorine. It is not very accurate. You can take a water sample to a pool store, or make an investment in a good test kit. It will pay for itself in the money you save in chemicals when you can accurately test your own water.
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
