There are a million reasons for cloudy water, however here are two that may be your problem. You didn't post a calcium reading. Your alkalinity is high, which along with high calcium will cause cloudiness. The fountain is a great idea - it will bring the alkalinity down, but it will raise your ph at the same time. So you will have to lower the ph with ph down, or muriatic acid. You can check the sticky at the top of the alkalinty forum. If your calcium is high, the only way to get it back down is to do a partial drain and refill. If you had a lot of algae, it could be the dead algae making the pool cloudy. The way to get rid of this kind of cloudiness it to keep your filter running 24/7, backwash frequently, and put a skimmer sock on the skimmer. If you have a sand filter you can also put some DE in to help with filtration. If you have any other questions feel free to ask.
