Results 1 to 10 of 12
Thread: I want green grass!!
    Smile I want green grass!!
    This is definitely off topic!! Anyone have a brilliant way for keeping your dog's urine from killing your grass? I've tried the "pills" from the pet store, tried tomato juice, bought some stuff at the pet store that you are supposed to spray on the spot when you notice it dying but I really think that is was just green spray paint. I spend waayy too much time digging up dead spots and replanting grass and watering. Anyone? Anyone?
    Default Re: I want green grass!!
    We have a lot of land, only cut about 3 acres, so I just trained my dog to relieve himself in the tall grass that doesn't get cut.
    Many people train their dog to use the same spot as a toilet, it doesn't take much, just some supervision and persuasion and a few "good boy's" when done correctly, by that I mean for you to take your dog outside, watch him sniff around, if he's about to go where you don't want give him a firn no and walk him to where you do want him to go, keep him there until he does his business, after several times of doing this, he will know that this spot is his toilet and will go there automatically.
    If you want, designate a small corner of your yard as his toilet, put a couple of boards as an edge and fill inside with round 3/4" gravel don't use crushed gravel, it hurts their pads and they won't like going on it.
    Northern Kentucky
    Set a pitcher or small bucket of water outside the door. Follow Fido around with the water, (or watch closely where he goes) and when he wets, dump the water on the spot. This will dilute the urine and hopefully eliminate your dead grass.
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    Scottsdale, Arizona
    I believe it's only the female that will cause the problems. Tomato juice works just fine for mine.
    No. Males kill the grass too, they are just more likely to go on the bushes or mailbox instead of directly in the yard.
    Every time your dog urinates you pour tomato juice on it?
    Scottsdale, Arizona
    Quote Originally Posted by Jeffski View Post
    LOL..... no, I feed them a little bit of tomato juice each day. Some people put it in the food but my dogs take a couple days to eat a bowl of food so I just pour a little in a dish and let them have it.
    I guess that explains the dead spot near my mail box
    Joliet
    What I've heard is that females are worse because they usually squat when the urinate, while the male stands up and lifts his leg. This action spreads the urine over a wider area and it isn't as concentrated.
    who knows
    dan
