Results 1 to 8 of 8
Thread: Can't get my Chlorine level up
    markphin is offline Registered+ Thread Analyst markphin 1 star
    Default Re: Can't get my Chlorine level up
    Janet,
    I have a leslie's test kit. I think it just tests for CC. which was about 1.0 this AM. I usually take for test for FC to pool store.
    Quote Originally Posted by markphin View Post
    Janet,
    CC will be the combined chlorine--if yours is truly 1.0, then you have something that's using up the chlorine in your pool, and you need to continue to hold your shock level to get rid of it. Most kits that only test for one thing test for TC.
    You're right, I meant TC not CC. I have brain fades over the winter around this stuff.
    So, just keep dumping bleach in until I can maintain Right. I thought I had it licked the other night, but by next morning it was down again.
    Yep, just keep at it. The more times a day you test and add, the quicker it's going to start holding....it's letting the shock level yo-yo up and down that takes forever to clear up a problem. YOu want to shock it, then maintain that level until the chlorine holds steady overnight.
    Might want to consider upping your CYA level just a little bit if you find that you're still having trouble holding a chlorine level throughout the day, once you get the pool cleaned up.
