Thread: How to Adjust pH and TA
    Maryland
    Default How to Adjust pH and TA
    Without a weight scale, how do you determine how much acid or borax to add to change the pH some amount? Same for baking soda to adjust TA.
    I read a thread that 1 cup of baking soda was 1 pound, is this right?
    Default Re: How to Adjust pH and TA
    I started this thread to address this very issue. It does seem that bulk density, that is the density of powder or granules sold for dry chemicals, does mostly seem to be around 1.0 - 1.2 g/ml which is about 1.0 - 1.2 ounce weight per fluid ounce volume or 1.0 - 1.2 pound for TWO cups. So one cup is about 1/2 pound (0.5 - 0.6 pounds).
    The best thing to do is to measure it on a scale, at least once, (subtracting out the weight of the cup, of course) and then report on the thread your results so others can know as well.
    Richard
    Maryland
    Richard
    That would be very convenient if one cup is about 1/2 lbs. 1/2 lbs is 8 oz by weight and 1 cup is 8 oz by volume.
  1. How to adjust CYA down
    By l8nite4me in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-13-2007, 04:27 PM
  2. What should I adjust ?
    By aswetich in forum DPD-FAS based testing
    Last Post: 07-27-2006, 07:33 PM
  3. Adjust TA first, right?
    By jnorris in forum Dealing with Alkalinity and Calcium
    Last Post: 06-30-2006, 11:07 AM
  4. Which one should I adjust first
    By Sunny32504 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2006, 01:32 PM
  5. Should I adjust anything ?
    By aswetich in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-02-2006, 09:34 PM
