Re: Pool is Running, First test....
One of the first things i'd ask your pool installer is "did you put any CYA in the pool?" If he did, and you add more, you may have a LOT more than you want, mainly because CYA takes a while to dissolve.
Your alk is low. I like to see in the 100 - 120 range.
I'd be concerned with no Cl showing up. You should see *some*. You may want to turn up the dial on your Cl feed before you develop a green pond. If you don't show any Cl tomorrow, you should put 3 quarts of plain, unscented 6% (ultra) bleach in the pool. That will bring your Cl to around 3 ppm, which will prevent the "pond syndrome"
Michael
