Results 1 to 10 of 13
Thread: New Solar Cover owner questions
    Default Re: New Solar Cover owner questions
    yep..between the lack of water evaporation and the shade from the sun, really does help a bunch. i would suggest when it's calm..say after a nice day of swimming in the early evening if it's calmer and sun is down but it's still fairly warm outside, leave the cover off for 2 or 3 hours a day instead of one. leaving it on for toooo long will make it like a greenhouse and promote algae growth..last year when i first got my cover and it was july and high 20s to low 30s, i left my cover on for 3 days and that's all it took for an algae bloom. chlorine was gobbled up at a much faster rate and it went from 5 to 0 in a couple of days and i figure by the morning of hot day 3, i had zero chlorine and one day of no chlorine and the heat was enough to make a mess..now, i'll add that was when i didn't have an swcg for steady output of chlorine and i can't remember if i was using cya to stabilize the chlorine or not at the time.
    I like to take the cover off during hot summer days for a couple of hours if possible, it warms the water nicely when there is no wind. Otherwise, our cover is on if we are not swimming. BTW, we cut slits in the cover where the rails for the drop in steps are set. Another thread shows the info on our homebuilt reel from plans Matt had.
