Results 1 to 10 of 11
Thread: how to reattach vinyl liner in spot where it's slipped out of the "channel"
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    Default Re: how to reattach vinyl liner in spot where it's slipped out of the "channel"
    Does this work for an overlap liner? I have about a 2-3 foot section that has dropped down about 3 inches. The liner is about 5 years old and this is the first time this has happened. I have removed two of the top plates and it looks like a long stretch to get it back over the top and underneath the coping strip.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
    Quote Originally Posted by gwrace1 View Post
    With an overlap liner, you need to just remove the top rail and the coping strip and pull it back into 'non wrinkled' If the liner tore, as opposed to just slipping, you might need topatch the area but basically do the same thing.
    Dec 2005
    South Central Texas
    My wife and I tried this weekend to stretch the liner back into place using 150-160 degree tap water. We could not get the liner any where close to going back under the coping. I do need to make a correction. I looked at our pool invoice and the liner is a jhook not an overlap. We've had various small leaks over the last 5 years so I'm wondering if a liner replacement would be the better option. We also have several pool walls that have rusted out near the bottom I've filed a warranty claim with Artesian since the steel frame has a lifetime warranty.
