Re: two-speed with solar panels
Is there really a difference between "negative head" and "vacuum"? As I see it, unless there is still positive head at the top of the panels, the water on its way down is pulled by gravity and produces a "suction" at the top. By suction I mean a pressure lower than atmospheric. If the system is sealed, that negative pressure "sucks" the water up from the inlet. But if there is a valve, the suction will make the valve open. As I said, it's possible that the valve will stay closed with a small amount of suction, but eventually it will open, and I would imagine the margin to be too small to be of use.
Thanks!
Luigi
30'x16' (irregular) indoor gunite/plaster pool, 10k gal,
Autopilot DLG-220 with SC-48 cell, 3/4 HP recirc pump,
solar panels, heat exchanger from 200 kBTU/hour Viessmann boiler
