Thread: First time adding cya
    Default First time adding cya
    Whats the real way of adding cya 17000 gal av ground sand filter. dont want to od on this stuff. pool guy said 2-bottles in bucket mix let sit, then add to skimmer will be doing this after i vac bottom this weekend done with baq conversion see other posts, thanksfor all your help.
    Indiana.
    Default Re: First time adding cya
    Don't add it all at once. Maybe a third or fourth of what you think you need. I prefer to put it in an old sock, tie the top and drop it in the skimmer. That way you can backwash as needed. Test it again before adding more.
    Maryland
    I've seen many ways to add CYA, tie it up in socks or pantyhose, pour it directly into the skimmer and let it get trapped in the filter so it dissolves over time, etc.... Why couldn't you simply add it to a bucket of warm/hot water let it dissolve then add to the pool or through the skimmer to disperse it?
    North Florida
    Quote Originally Posted by iwannapool View Post
    For me, that's the way I first tried to add CYA last year. Problem was...it just kind of sat there in the bucket of warm water. Agitating didn't help much. Mostly, I ended up with a bucket of cloudy, white water and a clumped up glob of CYA at the bottom that went through the plumbing as wet flakes.
    Now, I use the pantyhose trick and throw it in the skimmer where it can take all the time it wants to dissolve, usually not that much for me, maybe 2-4 days. And it IS all dissolved, as there are no flakes left in the pantyhose.
    Sandy
    This post lists a couple of other alternatives for more quickly adding CYA. Obviously, the Dichlor method should be used over time, not all at once, since it adds chlorine (FC) as well as CYA.
    Richard
    Kansas
    Hi!
    Here's a picture of our method from last year:
    http://www.poolforum.com/pf2/showthread.php?t=3254
    This year we just installed a 33' round & it needs over 5lbs of CYA.
    So i am going to try to use something like this method pictured here from PatL34 http://www.poolforum.com/pf2/attachm...0&d=1147012424
    I think this is what some of the other posts are referring to.
    ~Hoffmans
