Results 1 to 4 of 4
Thread: First results
    Default First results
    We just took the cover off 2 nights ago. Did preliminary tests before we added water to fill her up and be able to run the pump. We added chlorine to the water tank when we filled (we are on a well and haul water in for our pool from the city) so the chlorine would shock the pool and kill the algae. Initial report showed 0 CYA, so I went ahead and added CYA in a sock in the skimmer basket once we got the pump going.
    Test results this AM:
    24 ft round AG approx 15,000gal
    FC = 12
    CC = 0
    Alk = 120
    pH = 6.8-7.2 was a good 7.2 before we finished filling
    CYA = 0 - I could see it fading a little, but it needs to come up more
    cal - didn't test since it is AG
    My first thought is to add Borax (any advice on how much?) and let the CYA finish dissolving. Any other ideas?
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Default Re: First results
    Wait about 1 week to measure your CYA, it took mine awhile to reveal it's true value.
    Only a quick comment - your pool volume is probably not quite that high. Even if your walls are 52", you only have about 48" of water which would put your volume at more like 13,500.
    Thanks, Watermom. I thought it seemed high, but I was calculating the whole thing.
    I haven't added any Borax yet. I have the return pointed up to see if I can raise the pH that way first. I spent a long time last year getting the Alk down.
  1. first results, please help
    By vinouspleasure in forum DPD-FAS based testing
    Last Post: 06-13-2010, 02:42 PM
  2. More 234 results
    By drband in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2006, 02:49 PM
  3. Pool store results vs my ps223 results!
    By scarywoody in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-20-2006, 06:47 PM
  4. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  5. First set of results
    By maker in forum DPD-FAS based testing
    Last Post: 05-25-2006, 09:48 PM
