Re: Finally installing. A few random questions:
That's the thread I was referring to..
My wall has a different pattern, but from what I understand, Atlantic pools packages the same pool under 3 different names, with different wall designs.. The one I bought is called the J-5000.. they also call it the Vantage, and I don't know the third name, but I don't think it's gibralter... regardless, the pools are VERY similar... so I would assume the install procedure would be almost exactly the same.
