Re: Aeration and its effect on pH
Thanks Kurt ............... I just assumed I needed to get my pH closer to 7.6
If you think it is good a 7.2 I will leave it alone. Do I need to lower my TA which is now about 125 to 130? My water is still a bit cloudy and I had thought that it may be due to my TA level.
Also my water surface develops suds, almost like laundry suds. My water is very 'soft' which I believe is the cause with almost no indication of calcium. I assumed that I did not need calcium since I have a vinyl liner.
Any advice would be helpful.
