Looks to me like you just needed to let it circulate a bit longer. There is a powder you can use to lower pH..it's called pH Down...you can get it al WalMart in the pool section. It takes more and is a little more expensive than muriatic, but it is much easier and safer to deal with if the muriatic acid makes you nervous.
